WONT SHIFT RITE
1301 Views 4 Replies 3 Participants Last post by  hondaboi
WELL AFTER I INSTALLED MY CLUTCH KIT IT WILL NOT SHIFT RITE IT WILL SHIFT INTO TO 1ST THEN DROP RITE BACK INTO N. AND THEN WHEN I SHIFTED IT INTO REVERSE IT WILL ONLY SHIFT BACK TO N IF I USE THAT TOOL THAT IT CAM WITH TO SHIFT. ANY ADVICE OR HELP WOULD BE GREAFULL THANKS.
1 - 5 of 5 Posts
[No message]
Could be the sub gearshift arm isn't in the "V" of the clutch plate cam , causing the bike not to go all the way into gear .. I think you'll have to remove the clutch cover again ..
When you did the clutch did you have the bike resting on the rear wheels & rear rack ..
THANK FOR ALL THE HELP IT WAS MY BATTERY CONECTION WAS LOOSE.
NEVER MIND IT STARTED DOING THE SAME THING AGAIN??
1 - 5 of 5 Posts
