Won't go
5598 Views 8 Replies 7 Participants Last post by  Honda Mechanic
i got problem after problem now my gear indicated is flaching and in reverse is sperders and when i try to go forward, it bearly wants to move, even if itfull throttle. Does anyone know whats wrong or had this had before.
1 - 9 of 9 Posts
Sounds like it is in limp mode. Check the angle sensor. You can do a search for it in this Forum.
I would put my money on the angle sensor
i know this is a late reply but it might be your hidrolic pump because i looked it up in the manual and that is one of the number one reasons for the flashing signs, now if it wont go at all then **** that sucks because that is what it might be, look in your owners manual, trouble shooting section and it will tell you, sorry to be the barer of bad news.
I HAD THE SAME PROBLEM, THERE IS A SENSOR ARE WHAT EVER IT MAY BE CALLED THAT IS UNDER THE TANK. MINE WAS UNPLUGED, I BET MONEY THAT THAT IS THE PROBLEM.
Thats the angle sensor. I had that same problem. You could be flooring it and it wont move
Major is yours fixed
With the key on and you push the bike slowly does the speedo read 2-4MPH .. if not it probably needs a speedometer sensor .. If the speedo registers 2-4MPH then probably an angle sensor ..
Did you count the flashes ..?
If you install a new angle sensor on a Rubicon the new sensor must have pre-load on it as you install it ..
1 - 9 of 9 Posts
