1 - 5 of 5 Posts
Hi , I have a new winch that I installed on my Honda 450es. When I winch it in it works, but when I winch out it kills everything and the engine will stall. I replaced the battery and the voltage regulator. And it still does the same thing.. can someone help me??
Discussion Starter · #3 ·
I got it .. Fixed ! it was a terminal touching my frame because I hadn’t put the back brackets on the base plate of the winch. So every time I would lift my plow it would pull the winch forward and ground out on my frame..
👍🏻 Good job
1 - 5 of 5 Posts
