G
Guest
·Hi first post here! I have a 01 Foreman ES, one of the front wheel bearings was really loose, replaced the bearing, still loose. The new bearing fit tight in the knuckle, and the hub had a tiny bit of play but when you put it together you can move the wheel quite a bit at 12 and 6 o'clock. I'm guessing I'm looking at a hub (flange)?
