What tires
  • Mud bugs
    Votes: 0 0.0%
  • Gators
    Votes: 0 0.0%
  • Swampwitch
    Votes: 0 0.0%
  • Mud lites
    Votes: 0 0.0%
  • itp 589's
    Votes: 0 0.0%
  • Mudzilla's
    Votes: 0 0.0%
  • other
    Votes: 0 0.0%
1 - 6 of 6 Posts
Just wondering what 26inch tires i should put on my dads 350 rancher 2wd.
Its between the bug or the 589s for me. I'll let you bolt up my zillas if you want to try them out, but they are only 26x9. I would go with something that will spin easy. 589s gators or bugs will do the best.
The mud bugs work great ask Jeff what he thinks of them.
well everyone seems to stick by what they like use...so in keeping with that theme....mudlights.....actually i say this for 1 big reason...with the quad that you are putting them on every bit of weight you can save will be noticable...you might want to consider staying away from the heavy all out mud tires for that reason....just my 2 cents
Mudbugs in 26x12x12 have the most open/wide lugged tread from their lineup.They also are the lightest tire out in that tread pattern(even 589 and mudlites)I wasnt aware that they redesigned the 27 and 28 bug tread pattern to cut down on weight.My 28s lugs are 1" shorter in length and almost 1" skinnier across,they also added alot more of them around the tire(not as open of a tread),I noticed they get caked up faster and dont clean out as good as the 26x12x12 i had before...THIS IS ALL MY OPINOIN AND I FIGURED TO BRING THIS UP TO EVERYONE,JUST INCASE SOMETHING LOOKED DIFF BUT YOU COULDNT PINPOINT IT..IT DROVE ME CRAZY UNTILL I FOUND IT OUT>>> STILL A GREAT TIRE!!!!
1 - 6 of 6 Posts
