What breathers need moved?
1051 Views 1 Reply 2 Participants Last post by  mudlord
I put a snorkle on my 450 and i want to run all the breathers to the air box. im just going to drill a hole to fit them in and put cocking around it or something. but what do i need all run in the the air box i read a little about the carp breather, but other than that I dont know what other breathers to run there.
You need to run the vent tubes to the top of the snorkle, not the air box, I believe it causes negative pressure on the vent lines!! Run the front and rear differential, 2 vents from the carb, your fan vent, and you can do the brake vents also.
