YES!!!!!!!!!! I had the same problem but it's the right mount you just dont have the back hammered down good. You need to take the winch off the mount and beat the piss out of it until the mount in the back is flat on the frame. You can do this with the bolts in just loosen them up so it will move. It took me a while before I figured this out because mine hit the support on the head light too. Once you have it flat and the front u-bolts tight there should be about a 1/4 inch space between the support and the winch. Its a very very tight fit but it will fit.
