I need some tech advice from some experts. I have a 2012 Traxx 500 and I am noticing water in my fuel pump but do not know where its coming from. I have new ethanol free gas in the tank and i have also drained the tank to add new gas. The atv will run for weeks and then it will want to shut off and not start up again. i have dismantle the fuel pump and drain the old gas out and install which will work for a few weeks again and then the problem happens all over again. Could condensation becoming into the pump from the vapor
hose? I do not mud ride or bring the atv into water. So that is out the question. Here is a pic of the fuel pump drained. The top is gas and the water is below.
Tableware Liquid Sour mix Cocktail Solution
