Getting small amounts of water in oil. Air box is tight no leaks. I have heard some foremans are letting water leak in at the crank seal behind pull starter cover. Anyone heard of this?
yes very common on these bikes after awhile just take the cover off put some black silicon around it and put it back make sure that you fill in the drain hole on the bottom of the cover too....... should take care of the problem.......If thats not it i would check the vent tube that goes from the crank case to the airbox and make sure that it doesnt have a small hole or dryrot anywhere in it
