Wondering if anybody has had problems with water in,getting into the diffs,breather tubes look okay,has anybody had trouble with seals???
yep i am fixing the dame problem right now, i am putting a complete new rear diff assembly and a new axle in mine tommorow. the gear reduction found the problem for me. the teeth on the axle and and inside the ring gear rounded over beacause of all the rust and dirt over the years. i guess thats what you get when you by one that is used and not taken care of.yes i just experienced this problem, is cost me a rear axel and rear ring gear(totally my fault, neglect) any way if its not your vent tubes then a rear bearing has probably failed and is allowing water,sand into the rear diff, in the front it probably is a seal.
