I just installed mine....you'll love it! Like power steering! I can do donuts in the dirt and snow, now!
Lessons learned in the install....you'll understand when you get to those parts of the install:
Put the anti-rotation U-bolt on the vertical rather than horizontal frame peice. Mine has the bolt hanging down a bit since I bolted to the horizontal. Not a big enough concern for me to tear back into it to fix but since you will be in there.......you can do it right.
Be VERY careful with mounting the control. When I drilled, I barely nicked the gas tank. Also, on mine, I mounted per the picture and some literature pictures and my headlight bar guard hit it. I pulled of the guard and hammered it flat (it's really a tube) where it interfered and ground down the bracket to clear everything. Then, repainted. Not noticable. It beat the heck outta re-drilling the holes or making a custom bracket.
Good luck!
Mikey[/quote
hi just read ur piece about 424,did u get instructions with urs.i didnt and im not too sure where to start]
