As mechanical parts wear the tolerances change. Cam lobes wear. Valves can stretch etc. If the clearance gets to be too mcuh you hear a clicking noise. Engine performance suffers due to valves not opening like when they should. Valves can burn due to not seating correctly (if they are too tight) Basicly the engine is designed to run within certain Parameters, Adjusting the valves correctly helps to keep it running well.
It is not difficult to do, it just takes a little time.
