Hi All,
Im new to the forum, I live in the UK and i have a 2000 TRX450 S.
I Have recently Bought a 2003 TRX450es Chassis with axles and diffs... I am thinking of putting the engine out of my current 2000 manual shift into it, and I was wondering what difficulties i will come across while doing this and if it will actually fit.
I would be greatful if you could shed some light on the situation.
Thanks,
Tim
the engine will bolt right up. you will also have to install all the ES electronic devices, maybe even the wiring harness and display pod.
Hi All,
Thanks,
Tim
Well since the years are almost the same there pretty close look at your engine mounts and compare it to the 03 then review
