I have a Gorilla 3000 winch. I installed the winch and it works fine. However, occasionally it will not work. Here is the isolated problem. I spliced the push button switch hotwire in with the accessory port hot wire and sometimes it has power and everything works fine and other times it doesn't. I checked for grounded/loose wires and everything. Any advice or info would be great!
