DOES ANYONE KNOW IF 27X10X12 MUD BUGS FIT ON A STOCK FRONT RIM OF A FOREMAN 500. IF IT WILL GO ON THE RIM DO YOU NEED A WHEEL SPACER OR AN OFFSET RIM OR SOME COMBINATION OF THE TWO.
ALSO, WHILE IM ASKING HOW DO YOU DRAIN AND FLUSH THE FRONT AND REAR DIFF'S. I LOOKED, I DIDN'T SEE A DRAIN PLUG IN THE BOTTOM. I SEE THE FILL HOLE, BUT NO DRAIN PLUG. FOR SURE YOU DON'T HAVE TO JACK THE BIKE UP, AND SPIN THE WHEELS UNTIL THE GEARS SLING ALL THE OIL OUT OF THE FILL HOLE!!!!!
