to just check the spring you can take the header pipe off, use a long philip screwdriver to remove the screw on top of the adjuster and then use a long skinny flat screwdriver to turn the adjuster and you can feel the spring make the adjuster snap back down ( only have to turn it a little to feel the springCan I pull the adjuster out without messing anything up? I want to check the spring.
Thanks,
QUOTE ("harveje":3dq37dlg)
to just check the spring you can take the header pipe off, use a long philip screwdriver to remove the screw on top of the adjuster and then use a long skinny flat screwdriver to turn the adjuster and you can feel the spring make the adjuster snap back down ( only have to turn it a little to feel the spring[/quote]Can I pull the adjuster out without messing anything up? I want to check the spring.
Thanks,
