1 - 5 of 5 Posts
I'm think about putting a gorilla 2000 lb winch on my 2001 450es. Are these decent for use when plowing? I'm getting sick of my spring assisted plow lift. Also I've had slight problems with having enough juice to shift a lot and have the lights on at the same time on my wheeler. It has been better since the new voltage regulator and battery were put in, but I have to let it warm up for a while, or the lights will dim when I shift. Is adding a winch going to draw a lot of power and further complicate my electrical woes?
adding a winch is a good drain on the system. did you have the output on your stator checked??
Discussion Starter · #3 ·
No, I brought it in because the wheeler wouldn't shift at all. The voltage regulator fixed the problem. I guess I could get the winch and if I don't have enough juice I'll just have to fix the problem.
i figured id just throw it out there because the same sh*t happened to one of my machines.
Get a 3000# Gorilla!!
1 - 5 of 5 Posts
