Temperature sensor question
1291 Views 9 Replies 7 Participants Last post by  bc buck
I have an o1' foreman 450 that runs great until it warms up then it loses power and barely runs. Once it cools down it starts right up and runs great until it warms up again. Would this be a bad temp sensor? Do these bikes have a limp mode? I've swapped out too many parts to list (including the carb) and I'm pretty much out of ideas for things to check. Btw the oil pump seems to be working fine.
1 - 10 of 10 Posts
Really guys? Nothing?
I had a similar issue and it was the muffler. The baffles had rusted away and when running would actually block the exhaust when throttled. Just an idea, it sounded different, like when there is something against the back of the muffler and when I took it off it rattled.
  • Like
Reactions: 1
What I remember about the temp sensor on the older Honda quads was it only dealt with the oil cooler fan and warning light. No limp mode afaik. You need to determine if the issue is electrical or not. Checking for spark when it dies out might be easier said than done but could help.
  • Like
Reactions: 1
Thanks, trying a different battery right now. Stay tuned. Lithium went dead after 45 minutes this morning.
When it dies I have attempted to pull start. There is no spark or it would fire for sure.
Might be time to take it in and get it serviced and valves adjusted. Everything suffers with lack of attention. Sounds like something breaking down when the bike gets hot.
late on a reply. Make sure the fan is getting 12 volts and working. There are 3 Senors for the cooling system. Oil temp sensor on the bottom of the engine, a air temp sensor on front of the machine and a temp control module on the front of the machine. Could be any or all. My 450 foremen would heat up so I ended up changing all 3 sensors. the fan comes on and cools the engine when I drive slow 5mph or less for 1/2 an hour. Problem solved. P.S. the red temp light should come on to let you know things are getting hot. Good luck
  • Like
Reactions: 2
Honda rubicon 2005 no encienden los ventiladores cambie el censor de calentamiento revise cables cambie computadora y no puede funcionar en verdad no Ai nada para aserlo
1 - 10 of 10 Posts
