I have a couple of problems with my foreman right now and its all in the front end. My diff casing cracked at the mounting areas which made it loose in the frame and I had it welded back together and it broke again. So I am going to order a new casing on that side of the diff so that takes care of that.
Also, when I was putting my axles back in after getting the diff welded i noticed that the side of the axles that go into the hub were stiff. The side that goes into the differential was able to move freely and go at every different angle like it should. The side that goes into the hub was like a stiff board. Its not supposed to be like this right??? Anyhow so I am going to take those back out and ship them off to Gorilla for repairs.
Soooo im wondering... since I will be down for a while and I hate not riding im wondering if I can take my diff + and both speed sensor and some other plug off and run without the 4x4 system. Is this possible to do??? Will it still shift properly? Also since no axles would be in there would water/dirt get into the wheel bearings easier?
Let me know.
Let me know.
