dang Robb your rought on that thing.
Remove your floorboards, there is a plastic insert in the frame at the pivot point of the swingarm, using a screwdriver pop them out, just remember which side has the locknut. You will need a 17mm allen socket and a long breaker bar. being a newer atv, a impact might break them loose. unhook the rear brakes and vent lines first.
Use a set of jack stands/blocks under the motor to hold the bike up with the rear wheels touching the ground. unbolt the shocks and take the pivot bolts out and the whole rear assem. will roll out.
