For a full time 4x4 I have always found the steering on my bike to be very easy, especially with the GM limited slip additive in the front end. Since I installed the Perfex lift and HL springs I have found that the front end is very loose like its almost floating at higher speeds. It just doesn"t seem to hook up in corners as well as it did before the lift.
Does the lift change the front end geometry enough to affect steering?Would adjusting the Toe in or out help and what should I adjust it to ?
