So I just replaced my battery because the quad was getting hard to start. With a fresh battery she started up instantly, like she never has before. I delighted and soon went out for a ride. After about an hour or two, my four wheel indicator started blinking, then my shifting went out, then the screen died. This has been an issue with this quad for a while. I use to think it happened when I got it wet, but since winter, it has done both times I took it out, and it didnt get wet at all. So, I figured maybe the battery was getting weak and without enough voltage, the electrical systems wouldnt work properly. Hence, the new battery. Anyway, as soon as I limped it home with the foot shifter, I broke out my voltage meter and it was showing 11 volts. So it seems that it is not recharging right? Would this have to be the stator or is there something else I could/should check first? I just dont want to spend $180 + after spending $75, to find out that it wasnt the battery or stator. By the way, I have a pair of aftermarket driving lights on the quad. I think they have a 55 watt bulb each in them. Please help, my Foreman gurus!
