start in gear
Step 1: Remove the seat.
Step 2: Locate the START(ER) MAGNETIC SWITCH (the starter
relay switch). This relay is located at the very left-rear
corner of the electrical compartment right behind the
battery. There are two smaller wires coming out the side, one being LgR (Light green with a Red stripe)
and one being Y/R (Yellow with a Red stripe).
Step 3: Trace along the LgR wire to whatever point you
like, but somewhere easy to get to.
DO NOT USE THE Y/R WIRE!
Step 4: Attach a similar size wire to the LgR wire
anywhere and in any fashion you like, and then wrap the
joint with electrical tape. I suggest not cutting the
wire, but just stripping away the insulation for about
3/8", and then attaching the new wire.
Step 5: Route the new wire to your Cheater Switch.
Step 6: Connect another wire from the other connection
on the Cheater Switch to any place on the frame or engine,
making sure that it has a good electrical connection. If
using the frame, you may have to scrape off a little paint
to ensure a good electrical connection.
