I bought a new 04 Foreman in 05 because of the great deal i got. In water over the pegs it stalls out unless you are in the gas. I plugged the bowl drain line and sitting on hard ground it acts like it is in deep water it will not run unless gassed. I have tried rerouting the drain line to a higher position by the filler neck and it does the same thing as plugging it. If you route it above the carb it stalls. My brothers 05 will idle all day long siting in mod. deep water. my cousins 02 has been plugged since he bought it and it runs perfectly on dry land and in the water. This has been aggrivating since they can just tool around in the water and it doesn't give them trouble and i have to go through it wide open just to keep it running and if you get stuck your screwed because it will go dead if you let off the gas for a second. Any help on this will be greatly appreciated. Thanks.
