????snorkle kit????
2362 Views 4 Replies 3 Participants Last post by  joecamel
G
whats the best snorkle kit for the foreman 500???
how much is that gonna run me???
1 - 5 of 5 Posts
There are several... Triangle Snorkle kit, you can get online as well as others.. Different prices as well. Alot more expensive than a custom one. Are you wanting to buy the whole kit? If not, you can save alot of money by purchasing different material and making your own to your own specs. This is easy and most riders do their own custom snorkle because there really is nothing to them once you look at it. A wet Vac 2 inch hose and a 90 degree PVC elbow and some black RTV..and BOOM...your done..
once you install your snorkle kit, do you have to re-jet it ? i already had a jet kit installed. 165 main jet with the needle set on the 3rd clip.
mike
Slidell.. It will change it a little...Let Robb or someone tell you on that...I just put the DynoJet kit in both of them and had no problems... What you have may be fine.. You won't be dissapointed... Someone told me what to run with a snorkle but that was a long time ago and don't remember..
QUOTE ("SLIDELLFOREMAN":3pxltlb7)
mike
i have a snorkel, it is based on rincons plans. i have a hmf pipe with a 165 jet, everything else is stock in the carb. ive just bought a k&n filter and a dyjet kit. when i install this i will go to the 170 jet and see what happens.
1 - 5 of 5 Posts
