have stock exhaust and stock air filter with 2" snorkel reduced down to 1.5" into air box runs good when choke is up but cuts out when choke is down should i rejet and if so what size? or could i just move the clip on the needle? need help!
i used to have the same problem all i did was turn the air/fuel mixture screw a couple of turns i cant remember which wayhave stock exhaust and stock air filter with 2" snorkel reduced down to 1.5" into air box runs good when choke is up but cuts out when choke is down should i rejet and if so what size? or could i just move the clip on the needle? need help!
