I had mine going through some water. Nothing to deep just about 3/4 the height of the tires. Hit it a few times and now it is smoking out of the exhaust. Changed the oil and no signs of water. Runs perfectly fine other than it is blowing white smoke out of the exhaust. Any ideas on what it could be?
Did you pull your seat off and check your air box for water? Also check to make sure that the rubber hose is hooked up right , from the air box to your carb
White “smoke” usually means you’ve just gotten water in your exhaust, you may have an exhaust leak but it’s not that big of deal, mine does that too.
