Heres the stats: 2004 Honda Foreman 450ES, 220 hours, bone stock, no mods. Running Amsoil ATV, but it used to do it with Honda oil as well.
So from a cold start and a cold start only, after it has run a bit and achieved power in 1st gear, it will not do this again for the day.
I walk out to the shed, start her up. Once its warm and choke is off, I shift into reverse and back it out with zero problems and normal power.
Here's where it gets strange. I shift into first gear(shifts perfectly, smooth but crisp)...when i try to accelerate, she won't move forward(it would do the same in 2nd as well). If i keep slightly revving the throttle, maybe 800-1000rpms for about 10 seconds it will slowly start to creep forward and gradually be at normal power. Once it has gone through this once, its good to go. I could shut it down immediately after its gone through this, and it would start up and have proper power immediately. Aside to this it runs/shifts great. I'm just trying to fix small problems before they turn into big ones.
Thoughts?
Thoughts?
