Today I tried to fix my es system. All gears worked fine before I pulled off my old angle sensor. I put on the new sensor and now only getting R,N,1. Then --. I tried adjusting the clutch but the clutch adjustment is locked up. I made the mistake of heating it up, come to find out there's o-ring behind that...so I melted them. The emergency foot shift worked then locked up after trying to shift down. Now it's sitting at --. I took off the shift motor and the foot shift now is working just fine with out the sensor on or motor. I wanted to replace the angle sensor because the gears would slam into place when driving around. Maybe my gear shift motor is bad?? Or do I have to pull the front cover off my transmission to fix the clutch screw?
