Do the entire top end. Bore the cylinder and upsize the piston. They go up in .25mm increments all the way to 2.0 millimeters. Your machine shop will tell you how much of a bore you need. Also have the machine shop work the head. Clean and reseat the valves and replace the valve stem seals. Its not too hard if you have some mechanical skills.
You need a new piston with rings and a top end kit. I use Wiseco pistons and get the top end kit off of Ebay. Good luck.
