My foreman was running like crap this weekend, I took the plug out of the drain tube and it ran great the rest of the day. What gives????
Like I was saying in your other post the tube keeps the carb from flooding due to dirt, sticky float or even rough terrain. Just leave the tube unplugged to function as its designed to do. When you want to play in the water just use the bolt on the rear shaft rubber boot to plug the tube.My foreman was running like crap this weekend, I took the plug out of the drain tube and it ran great the rest of the day. What gives????
QUOTE ("big_daddy_bigfoot":35egfl3z)
Like I was saying in your other post the tube keeps the carb from flooding due to dirt, sticky float or even rough terrain. Just leave the tube unplugged to function as its designed to do. When you want to play in the water just use the bolt on the rear shaft rubber boot to plug the tube.[/quote]My foreman was running like crap this weekend, I took the plug out of the drain tube and it ran great the rest of the day. What gives????
same here looked under there one day and it was gone along with the wire that is supposed to hold it inMy check valve is M.I.A!
Guess he's (bigfoot) is not going to answer??i was just reading a bit of this post and i too had an issue similar to that...
i was riding a few weeks ago and we had gotten stuck, like really really stuck, like we had 5 bikes pulling one guy out of a hole and it would barely move. he was stuck like a hair in a biscuit. anyway, i ran out of gas and had to switch to reserve for the ride home. as i got it onto my trailer, it died...the tank was bone ass dry... i filled it up to the top, turned the gas shut off a few times to get if flowing...had a horrible ride that next day, my bike kept sputtering and stopping and couldn't figure out why...well it hit me on the way back, i had too much gas in the carb and it was flooding out b/c my drain was plugged so i took a little gas out of the tank and i was fine for the rest of the day...sooooooo
maybe if you adjust your carb a little bigfoot you may not have to leave it open...
p.s. sorry for the long post.
The carb sucks water in causing it to spit and sputter. I now just plug it when I think I'm going to be in water.i was going threw a hole that was mostly water wen i didnt hav my tube plugged and it started cutting out really bad and almost died so jus 4 tha heck of it i moved the tube to where it wasnt under water and then it stopped cuttin out and it ran fine not sure y it did that but it did
