I’ve been searching on this forum for an answer but haven’t been able to find a clear one. I have a 2001 Rubicon and I changed the oil pump a little over a month ago and have put about 4h of use so far. (speed sensor is also new)
The problem I now have is that the ATV won’t move. I can shift through R-N-D-L but when I press the gas it won’t advance. It’s like I was pressing the brakes because I feel a resistance. I used to hear the control motor when shifting but not anymore. The control motor was noisy (but that might be normal?) I removed it, cleaned it and also checked that the gear in the crankcase moves freely.
I have a feeling it is somehow related to the control motor/angle sensor. Is this a common problem? Any insight?
