THE OIL PUMP IN THESE TESTS IS STARTING TO GET WEAK (BUT IS STILL GOOD) A NEW PUMP WILL MAX THE HONDA GAUGE WILL OVER 160 PSI...
When the pictures open click again for full size...
This is the 8mm allen bolt you remove the check oil pressure ..
This is the Honda adapter for the Honda oil pressure gauge..
This is the oil pressure at idle .. Minimum is 16 PSI..
This is the oil pressure at 5000 RPM .. Minumun is 116 PSI ..
Fluke test
This is the Fluke adapter for the Fluke PV500 pressure/vacuum adapter..
This is the oil pressure at 5000 RPM .. Minimum is 116 PSI ..
Fluke test
