I have read before that on the older body style rubicons the the largest tire that you can mount on the front is a 26x9.50x12 because any wider or taller and they will rub the fender braces. Does anyone know if this is true?
Those things are god awfully expensive for no more than they are. The highlifter would cost you a arm, leg, and 9 toes, the moose on the other hand is only half that (around 50). Cheap solution...just hammer them in or build your own set.there is a fender kit you can buy from Moose or Highlifter that is a fender bracket that replaces the old one which will stop any rub.
