Hello is it possible to install the clutch kit springs with out removing the clutch?
M myers4712 · Registered Joined Feb 3, 2006 · 137 Posts Discussion Starter · #1 · Jun 14, 2006 Only show this user Hello is it possible to install the clutch kit springs with out removing the clutch?
Honda Mechanic · Registered Joined Jul 31, 2005 · 1,236 Posts #2 · Jun 15, 2006 Only show this user Yes the centrifugal clutch must be pulled to change the springs ..
M myers4712 · Registered Joined Feb 3, 2006 · 137 Posts Discussion Starter · #3 · Jun 15, 2006 Only show this user Ok is there any way to pull it without the Honda puller. I have other pullers. Thanks Dustin
R Robb · Registered Joined Jan 15, 2005 · 2,427 Posts #4 · Jun 15, 2006 Only show this user yeah you dont need the fancy tool, just get creative. When we did mine we didnt use the puller.
M myers4712 · Registered Joined Feb 3, 2006 · 137 Posts Discussion Starter · #5 · Jun 15, 2006 Only show this user Ok cool I guess I will wing it then. Thanks guys
Honda Mechanic · Registered Joined Jul 31, 2005 · 1,236 Posts #6 · Jun 15, 2006 Only show this user When you use a different puller be careful you don't bend/damage the centrifugal clutch..
M myers4712 · Registered Joined Feb 3, 2006 · 137 Posts Discussion Starter · #7 · Jun 15, 2006 Only show this user Ok thanks guys.
