If I were to take the spark Arrestor out of my 2005 Rincon 650, would I notice a gain in power? And how much different would the sound be?
It probably wouldn't change anything, except you'd no longer have a spark arrestor. If you take the whole tip assembly off it will make it a lot louder. No power gain though. You might want to check eBay for the 2" exhaust tips. Again, no gain in power, but it sounds good.If I were to take the spark Arrestor out of my 2005 Rincon 650, would I notice a gain in power? And how much different would the sound be?
No, if you totally gut the muffler and run a straight pipe you'd loose power, just removing the spark arrestor won't do that though. That's why aftermarket exhausts flow more air not less.i thought if you take the spark arrestor off you loose back pressure and in turn loose power?
oh, i was always told i would loose back pressure and power. when i took mine off , when i put it in gear, it would die and did it a couple times then i put the spark arrestor back on and then it didnt stall again so i dont know lolNo, if you totally gut the muffler and run a straight pipe you'd loose power, just removing the spark arrestor won't do that though. That's why aftermarket exhausts flow more air not less.
that makes sense but you would need to get a programmer correct?Sometimes when you remove it you'll need to adjust your jetting or EFI tune, which is why it might stall with it removed. Once you have it tuned you would make more HP.
I was told by my mechanic that if I didn't replace mine and got caught in the woods without it I would not only get a big fine but I would lose my ATV!If I were to take the spark Arrestor out of my 2005 Rincon 650, would I notice a gain in power? And how much different would the sound be?
