Rincon level switch ?
5792 Views 7 Replies 5 Participants Last post by  realrider650
Does the 650 have a level switch.my buddy has problems climbing up short steep rises (like out of a creek bed) it will hessitate and sometimes stall out ,we checked float level and overflow tube, all was good ,tried to make it do it by parking it and tipping it but it doesnt do it when you want it to only when he needs it to keep running
1 - 8 of 8 Posts
What's a level switch? I'm guessing it doesn't have one if I don't know what it is.
Do you mean a "bank angle sensor" ..No the TRX650 doesn't have one ,but the TRX680 does..
Thanks,we will keep an eye on it and try to figure out exactly when it does it
Honda Mechanic... Is that because the 680 has fuel injection...and the 650 has a carb? I had heard that if you tilt the 650 back to far ( doing a wheelie and ending up on the back rack ) that all of the oil, or transmission fluid will run back and you could mess the bike up bad.. Is that true?
Yes the TRX680 has a bank angle sensor because of the EFI ..
I've heard stories of guys that do wheelies for several telephone poles ,that's a long way especially if the bike has an oil bath crank type .. I don't know how far a TRX650 Rincon would be safe to wheelie ..But I'm sure that when it's in a wheelie that most of the 2.9L of oil is inside the sub-transmission case ..
I have ended up on by back rack more times than I wish to count...I haven't had any oil or gas in my air box or any where else...The quad will run standing staight up as long as you keep your thumb on the throttle...However standing on the front rack is a different story
G
QUOTE ("Canadian Foreman500":2ql7bckw)
i have the same exact problem problems climbing up short steep rises (like out of a creek bed) it will hessitate and sometimes stall out ,
i was told the steam from the engine gets into the intake a chokes it out ????? what do you think
1 - 8 of 8 Posts
