Does anyone know Honda's recommended tire pressure for the stock radials that come on the new 680?
(Dunlop KT511 front and KT515 rear)
Thanks in advance.
Thanks in advance.
Yeh... its like 4 in the front and 3 in the rear. I find, as do others, that this is too low. I'm liking 7 front, 5 rear. Then again, I weigh 250.Does anyone know Honda's recommended tire pressure for the stock radials that come on the new 680?
Thanks in advance.
No problem. My OEM Rancher tires called for 3.6? I think. I was running them at 3 psi with good results, so that's what I set the Rincon radials at. It does handle like crap at 3 psi (with the radials) for sure. Every bump just about jerks the handlebars out of your hands.:thumbup: Didn't read carefully enough. Thought you were referring to the tires on the rincon. Don't know if it helps but my brothers 500 Sportsman with factory radials calls for 5psi front and rear. Bike handles like crap if they get even a little below that.
Couldn't wait to get rid of my 11" wheels for the same reasons. My bike also called for 3.6 psi which was ok with the stock tires. I found that it handled best with 3 psi F&R with the 6 ply Bearclaws I had on the 11"s.[The reason I bought them in the first place was to get away from the Rancher's unusual sized 11" rear rim. Once I wear the Rincon tires down, I will have more tire choices with the normal "industry standard" 12" rim.
