Ok, I was recently having some trouble where My ES wasn't working and the wheeler wouldn't start. The dealer changed the voltage regulator and that seemed to fix everything. It started right up, the ES worked great, etc.. But after the wheeler set for 2 weeks the bike wouldn't start with the starter. I could pull start it though. The battery is only 6 months old and was just fully charged when I had the voltage regulator swapped. Is there any type of test I can do to find out if something is draining the battery while it is off? Is it normal to have to pull start these after setting only 2 weeks if the battery is good? What could I look for as something that would cause a battery drain?
My fan isn't kicking on either, I think the wire plugged into the thermosensor may have come disconnected again. Could these problems be related?
Thanks!
Thanks!
