I have a 06 foreman with 27" mudwisers on it, The other day i was going up a hill with a trailer on that had a little weight on it maby 350 to 400 lb just about to the top of the hill and i broke the u-jount has anyone had this problem ?
IF YOU WOIRED BOUT BRAKEN THE U-JOINT THEN GET THE TURNER U-JOINTsounds like when you put a lift in it happens to a lot of you guys
<a href="http://www.turnercycles.com/index.asp" target="_blank">http://www.turnercycles.com/index.asp</a>were is a good spot to look for the turner u-joint
ESDid your shift fork bend on an es or s?
