when i pull my left brake(rear) i goes all the way to the grip without any tension on it, if im running in like 3rd gear and i push the reverse button in and then pull it it will give tension and only go back about halfway, do i need to adjust my brake cable for just the brakes or are my rear brakes completely bad, also when i push the foot brake it doesnt even stop at all...im guessing that my rear brake is gone, what are the steps to go about replacing the rear brake?
How is the travel on the foot brake , it is connected to the rear as well . If the foot brake is ok then adjust the rear brake cable for the hand brake at the rear drum by turning the butterfly screw in a few turns and see if that helps.
Honda Foreman Forums
