Hi Everyone.I'm replacing the rear axle in 98 450S with OEM honda axle. Seems as though the axle is about 2 inches too short. Brake panel, dust cover bolt on fine. Axle slides through differential (From Right to Left) fine. I hand tighten right axle nut. Then Put on collar on right side of axle tapered inward. If bearing is sitting at 11.5 mm deep inside the axle housing, the axle housing will not be flush with the differential? If I take the collar off it, the hubs will bolt up fine. Bearing is new Allballs brand. Anyone had this problem? There is no Part# on the axle it's self, but it was new in the honda box and has the correct part number on the box, just seems to be too short. Or wrong width bearing? Any Ideas? Thanks so much...
