Rancher420 fpa 09 fuel issues
1.8K views 0 replies 1 participant last post by  Kevin Koski
#1 ·
Welll here lays the problem and the course I'm taking to fix it.
Ok after running it and it gets warm it will fall on its face but it will idle ok. So if I wait about like 3 min it will e fine again for a little while then will fall on its face.
Well I believe it's a fuel issue it's not getting enough gas. So I pulled the gas tank out and ran the pet **** on and reserve and I noticed that the flow was very little. In my eyes so I took it apart and ran the petcock in a ultrasonic machine for 12min . And blew air through and on seemed like it was still plugged and reser.ved was blowing good. And tested fuel pump and that was iffy. The filter for the rank was plugged
So I'm guessing that fuel pump was working over time for more fuel and it could get it . So my fix is new fuel pump and new petcock because I think petcock is plugged to.
I'll update when parts arrive. Any one need the part numbers I'll post them .:mad:
Hope this helps someone.
