i dont think there is an actual kit out there. you best bet would be to get some pvc at your local home store and start playing around with the pvc to see what fits.
mine is not installed yet but i have everything cut to fit. i used 1 1/2" pvc about 3" long coming out of the air intake box then an adaptor to go to 2" vac hose(so i could snake around the motor and radiator) with heat tape wraped around the hose so if it does touch the motor it will not melt, then 2" pvc from the fender up about about 2' with a 90* ontop. the reason its not installed is i have not decided where im going to bring the pvc up, aka hole in fender or out the radiator hole.
