Hi. Relatively new to the atv world. The only hose from the bottom of the carb (with the one way valve) may have come unattached from where it connects (if it connects somewhere) as it was leaking fuel. I cooked the starter motor and battery because I was trying to start it with no fuel. When I pulled the end of the tube above the carb to stop it from dripping fuel, the air filter housing filled with fuel. Where does this hose go??? I have the filter housing and starter motor out. The pull cord is stuck also. How ****** am I? Its a 2004. Thanks for your help.
