when i take my pull start off to clean the crap out of it to reseal it up, are things going to come falling out of it or is it bolted down to the cover so that it wont fall out unless u undo the bolt holding it all together?
also on rear drum brake how do you adjust it to become tighter, rite now i can pull it to the grip without any resistance, but if i push the reverse button in(even when not wanting to go into reverse)and then pull it it will go only halfway with resistance or how do you change the pads on it
