1 - 7 of 7 Posts
I have a 2005 TRX500ES. When i am in 5th gear wide open, and sometimes 4th gear, the bike will stop shifting. On my screen the number 5 ( or 4) flashes and the bike will not shift. However, if i shut the bike off and turn it back on, problem solved. Until i hit 5th wide open again.has anybody had or heard of this problem, if so what is the fix?
I worked on a 2006 Recon that was doing the same thing. Does the bike seem to only do it when you run a gear out to a higher than normal rpm?
Discussion Starter #4
It was yes. I replaces the angle sensor and all was fixed. Until now, now im stuck in neutral and i cant even manually shift.
Same thing happened to my mom's 450 foraman, but that pos has bigger problems lol, just flick the key on off real quick lol, but what does cause that?
Sent from my moto z3 using Tapatalk
1 - 7 of 7 Posts
