Yes, when key switch is turned on, the switch lites up.
Not exactly sure how the switch was wired. But as I remember, a hot wire went to one end of switch and out the other end to the pod light. Another wire connector was in middle and it went to ground which gave the switch a hot wire and a ground for light at switch. Most switches have instructions with it. I just followed instructions and not positive, but believe this is how it worked.
Mine is hooked a little different however than most on here. Most put a switch on the wire going from the main switch to the pod light and believe the wire (green) is the ground and ground wire is on switch. I did different by hooking a separate hot wire going to light and switching with the hot wire and use a ground that is grounded all the time. It has been a while since I did it, but this is how I remember it being done. I just wanted my pod light to be independant from main lights.
