I have a 04 foreman 450. I bought it used and the previous owner had it rebuilt. I took the engine down because it started smoking bad. I honed the cylinder and measured to find out I have a 0.008 clearance between my piston and cylinder wall. Too much? Should i just find rings with the right end gap and put it back together or buy a stock piston and cylinder. Or does anyone know it I can buy rings that are wider, so they still grip the piston while sealing against the cylinder. Its already been bored over a pretty good bit, supposedly bigger than a foreman 500 is. Any help would be great! Thanks Guys!!
