1 - 11 of 11 Posts
What is the best way to get more power in my foreman
rejet, air filter, and clutch kit. them are about all the basic things you can do to it without getting into the moror. if you do want into the motor put a BBK in it with a cam, you will have decent power if you do all of this.
-Aaron
Discussion Starter · #4 ·
QUOTE ("MAD MUDDER":c77l0y62)
-Aaron
i hav put a 135 main jet in the carb(came with hmf) and i thought about getting a k&n but i heard that i takes in a little dirt is that true? and what does the clutch kit do?
I actually noticed a big difference in power when I added my Triangle Snlorkel. It said in the directions it will increase H.P. but I didn't really believe it, but it is noticeable.
Discussion Starter · #7 ·
QUOTE ("mudder fudder":s0k2bt0d)
well i made my own snorkel it acted like it was restricting the air but i put a bigger main jet and maybe it will run better.And does anybody no if i get a performance clutch kit sense it adds more low end power does that meen it will take away from my top
Discussion Starter · #9 ·
QUOTE ("Dirty4man":eek:ew66mzk)
The clutch kit will not give you any HP gains or change you speed, all it does is stall the clutch about 500 rpms
ok well i see that you have a clutch kit would u recomend it?is it worth the bye?
Discussion Starter · #11 ·
QUOTE ("Dirty4man":1w56wier)
IMO the clutch kit is a great mod and worth the money for someone who play's in the mud.
ok thanks
1 - 11 of 11 Posts
